Desuperheater water flow control ideas
For a heatpump project, I need to control the flow rate of hot water through a tube in tube desuperheater. Depending on the operating conditions, I need to regulate the hot water flow from 0.16 GPM to 1.5 GPM to heat it to 120°F. What are good ways to do this?
RE: Desuperheater water flow control ideas
Good luck,
Latexman
They come in various types, mixing valves are the most common, but you can also control one inlet flow based on the outlet temp.
No electronics, no external connections.
Plymouth Tube
google "mixing valve"
>>>>>>>>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.>>>>>>>>>>>>
