Solid edge with XY Data
Is it possible to make curves in a Solid Edge 2D sheet with different XY series? These series are in excel and have more xy series next to each other ( like xyxyxyxy) with visual basic?
Or is it possible to make these curves with a formula in visual basic that takes data from an text or excel file?
Thank you, Andries
Thank you, Andries
RE: Solid edge with XY Data
The long answer - you need to write some VB that will open the excel file, read each set of co-ordinates and create a spline curve from the points in a draft file.
Alternatively you could split/edit the excel file into seperate files to leave just one set of curve co-ordinates ie. one column for X, one for Y and add a third column that is Z=0 for all points.
Then use Curve by Table to put generate the curves in a part file.
You can then create a draft of the part(s) and show the curves, or put the parts into an assembly if you want a draft of all of them.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
But i think the curve by table option will be alot of work, because i got A lot of xy series
Im going to try the first option, and if i dont get that working i will use the alternative option.
