NEI Nastran - Point Break Command Problem
Hi Guys,
1st of all I like to say that im very new to NEI NASTRAN and FEMAP and the FEA Packages. Im using NEI Nastran together with FEMAP and I have come across a problem which I hope some of you will be able to help with ease. I need to project a point on to a curve which is at a different Z value. I knw by using the break curve by point command the cuver breaks at the point of the x value of the point and projects the point onto the curve. But on some occation the projection of this point has been onto a different x value on the curve and I have no clue what I am doing wrong.
Any Advice is highly appreciated.
Cheers!
