Accuracy of Isocircles
Given a cube with inscribe circles on each of the faces, prove the isocircle function of AutoCAD produces a true presentation if the cube is viewed an isometric view.
I tried to prove this by rotating a square with a inscribe circle along a hinge (segment bc) which would be the right vertical edge of the square. The rotation was 45 degrees and the result is View B.
Then I tried to rotate the result as viewed in View B along hinge (segment cd). I first tried to do this at 30 degrees but I could not reproduce to the same aspect ratio of the major and minor axises of the ellipse within the given cube I am trying to prove true. However I had to do this rotation at 35 degrees to get close but it still was not the results I expected. My estimated result is View C.
In theory when a circle is rotated it produces an ellipse. A circle is just an ellipse with the major and minor axis's being equal. I tried to rotate View A appropriately but I could not reproduce the ellipse in exact proportion.
I know how to use AutoCAD to produce the ellipse using isoplane and isocircle. That is how the cube was created functions but that is not the scope of my question. Basically asking to produce one side of the cube from VIEW A as a Isometric view.
Please provide reasoning and support of any proof or this proof you provide.
CAD drawing and JPED is attached.
Very Respectfully,
Raymond Di Leo, Jr.
Very Respectfully,
Raymond Di Leo, Jr.
RE: Accuracy of Isocircles
If you analyze an Isometric direction it will show 1, -1, 1 (for SouthEast Iso). So, rotating the 2D geometry by that amount about the hinge bc by 45 degrees makes sense because ACOS(1/SQRT(2)) = 45.
For the next step, though, the angle off of the XY plane for a Viewpoint of 1, -1, 1 (or about the segment cd) would need to be ACOS(SQRT(2)/SQRT(3)), about 35.26439 degrees.
