Depth of Flow in Pipe
For gravity flow in a pipe, I want to determine flow depth for a given gpm, pipe ID, slope, and Manning friction factor. The flow can be assumed steady and uniform. Flow is less than 1/2 ID.
Is this an iterative process with the Manning equation and hydraulic radius or is there another expression that will determine the flow depth outright?
RE: Depth of Flow in Pipe
I think the crux of the matter is I need a relationship between depth and hydraulic radius (Rh) which I could substitute into the Manning equation for flow. Then I could solve the Manning equation for depth.
However, I have not been able to figured out this relationship through text references nor through geometry. It was my hope that the depth .vs. flow relationship would be a common enough need that the relationship has been presented, but (so far) overlooked or undiscovered in my search of the gravity flow references I've obtained.
http://ppi2pass.com/Errata/CERMApp19c.pdf
This link is from the ppi2pass site, the ERRATA for CERM 8 , 1st printing, appendix 17 (Civil Engineer's Reference Manual)
Clifford H Laubstein
FL Certified PE #58662
Sub getPartialPipeFlow()
' Partial pipe flow subroutine
'Iterate with incremental TRIAL_D until pipe_flow_Partial = Given flow
' Enter here with TRIAL_D = depth of flow
' SLOPE = Slope in ft/ft
' diaFt = Diameter of pipe in ft
' Routine returns:
' AREA = Area of pipe at flow
' PIPE_FLOW_PARTIAL = Discharge, CFS
' VELOCITY_PARTIAL = Velocity at flow
'circular
x_Val = (2 * trial_D - openDiaFt) / openDiaFt
If Abs(x_Val) < 1 Then
ArcCos = -Atn(x_Val / Sqr(-x_Val * x_Val + 1)) + 1.5708
PIPE_THETA = 2 * ArcCos
Else: PIPE_THETA = 0
End If
area = openDiaFt ^ 2 / 8 * (6.2832 - PIPE_THETA + Sin(PIPE_THETA))
AK = 1.486 * ((((6.2832 - PIPE_THETA + Sin(PIPE_THETA)) / 8) ^ 5) / (((6.2832 - PIPE_THETA) / 2) ^ 2 * (trial_D / openDiaFt) ^ 8)) ^ (1 / 3)
pipe_Flow_Partial = (AK * trial_D ^ (8 / 3)) / manN * slopeOut ^ 0.5
End Sub
