Chilled Water Coil
Chilled Water Coil
Dear friends,
I have a very simple chilled water system with the following characteristics
• Warehouse application
• Two chillers with constant flow pumps
• Four AHUs for with 3-way control valves
Sequence: When space temperature reaches a setpoint, flow through AHU coil stops and chilled water is bypassed.
Question: Why do I need balancing valve in bypass line while it is only ON/OFF 3-way control system. I have a balancing valve in return line downstream of 3-way valve
Fayaz
Fayaz
RE: Chilled Water Coil
The return line balancing valves trim the flow to each AHU depending on how far each is from the pump.
