AS1170.2 2011 Local Pressure Factor Area
There is a note on page 39 of AS1170.2 2011 pertaining to local pressure factors that says "The side ratio of any local pressure factor area on the roof shall not exceed 4". This was not included in the earlier edition of the code. Previously, as far as I know, you would apply small localised high pressure areas, either (a x a) or (a/2 x a/2), along the length of the purlin, and it would be these areas that we would apply the local pressure factor k[l].
What are the implications of the above note in the more recently published code? Do we now also consider an area of (a x a/4) when designing purlins?
RE: AS1170.2 2011 Local Pressure Factor Area
Recommend if your designing in Australia that you get a book Design of Portal Frame Buildings, 4th Edition, S. T. Woolcock et al.
Commonly what you are referring to is called patch loading. basically the patch in the older codes was undefined in dimensions so you could design with a long slender patch if this gave you the worst loading position. This new requirement limits the ration of the side dimensions to 1 : 4. so if you patch ahd a side legnth of 1m the other side length would be limited to 4m max in length.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
extract from clause 5.4.4 "The RC1 case only applies to flat or near-flat roofs (slope less than 10°)".
I don't believe that the standard define two different roof pitch's a roof. clause 5.4.1 diagram top right the roof pitch is unchanged. The standard clearly defines gable roofs not a change in roof pitch.
