Chilled water and hot water filteration
I am working on HVAC renovation of an old school that has failing and clogged hydronic pipes. Until we replace these pipes, what is the best temporary and economically feasible solution to filter hot & chilled water and keep boilers and chillers to get damaged because of scale and debris from piping?
RE: Chilled water and hot water filteration
Course and fine in series.
Two sets in parallel to allow baskets to be cleaned.
with situation you have you should consider additional device, installed in series with strainers. there are many names for it, the most frequently i hear about "microfilters". they are advertised to gradually remove dirt from old piping. i tried it couple of times with excellent results. google Caleffi, they developed large operations in usa, and Taco is there as well.
