Question on press-fit
If you had to machine a shaft to be press fit into a bearing
with a inside dia of 1.436
what dia should shaft be machined ?
RE: Question on press-fit
What is the min/max ID size range of the bearing?
It sounds like you could take advantage of Machinery's Handbook. I imagine they cost $120 new but it will be one of the greatest investments you can make.
http://www.industrialpress.com
if I remember right
The fit depends on many factors. Mandrake22 mentioned some of them.
In metric world (metric bearings - obviously not your case) they use the ISO system of fits. You'll also find it in the Mach. Handbook or in the manufacturer's catalog.
If you decide to buy the BOOK, check first
www.bestbookbuys
for the best - what else - book prices on the web.
gearguru
Try this link for bearing and housing fits
E
http://www.conweb.com/tblefile/bearfta.shtml
www.geocities.com/motorworksnf/123
