bore field motor
bore field motor
One of the borefield um working on had all phases reading above 3mega ohms against earth before lowering the motor on water and under water results changed to 0.245mega ohm against earth,softt starter display loss line on all phases and gate open c.
RE: bore field motor
Yes there is. The internet is gradually killing all forms of grace or decorum in the written word. What you see is the new way to ask a question via the internet -one merely states a few random details of his/her latest crisis, then sits back and waits for comments from the millions who waste countless hours on the web.
My translation - "My motor seemed fine until I plunged it under water, now it appears to be shorted somehow. I don't want to bother with trouble shooting it, will someone please tell me what is wrong?"
Bill
"Why not the best?"
Jimmy Carter
I will try to help. Evidently water got into the motor or cable connections when it was submerged into the borehole. Nothing to do but pull it out and check for water in the motor, cable box, or as said in splices in the cable. Better sealing is needed obviously. Some submersible pump motors are oil filled, maybe there was no oil. The cable should not have any underwater splices actually, maybe a new cable is needed. Just some ideas.
What is the voltage and KW rating of the motor?
raevskii
