Changing EOS from one to an other object in Aspen+
Hello everyone. I have to change the EOS from RK-Soave to PC-Saft in my simulation. Only in the reaction area should be PC-saft used. But when i come out from the compression (RK-Soave) and go in the first reaction plug (PC-saft) the temperature rises only because of the EOS change. Does someone know how to fix this ?
RE: Changing EOS from one to an other object in Aspen+
I found it out by myself. Just for someone hwo whants to know:
build a heater between your two objects with different EOS and give the heater the EOS of the following. The temperature of the heater should be transfered from the inletstream.
