Dimensioning to a datum plane
In the sketcher task environment, when I want to dimension a sketch entity to a datum plane, if there is another sketch line "on top of" that datum plane, that sketch line is automatically selected instead of the datum plane. The only way to dimension to the datum plane is via the quick pick dialog or by manually setting the selection filter.
Is there a way to set a "selection priority" in sketcher to datums? That would save a lot of hassle.
NX8 Win7 i7-3770K@4.3Ghz 16GB Quadro2000
RE: Dimensioning to a datum plane
Try sketching in 3D space so you can select the datum plane easier.
It also appears there is a selection filter for Datums as well.
Fighter Pilot
Manufacturing Engineer
You've already listed your options, use QuickPick or set a filter. What more do you want?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Did you know that you can resize the datum planes so that they are easier to select?
When dimensioning to a datum plane I got into the habit of always using a perpendicular dimension. The datum plane must be picked first, but it just seems a little easier when doing it that way. It works nicer when the datum plane is on an angle too.
