Hot Work and Fire System Impairment Tags
Most of the property insurance companies have some good hot work permits - FM's is the best. Anyone know where i can get a good hot work permit to give to clients? I cant find anything in NFPA 51B.
Same question for tagging out a fire system/fire control valve. I recall seeing a very simple tag example in the CFC (IFC) awhile back but it didnt have much detail.
Keep in mind, i am aware of the needed precautions, I just would like a good hanging tag for both. Thanks.
RE: Hot Work and Fire System Impairment Tags
http://www.tamhsc.edu/ehsm/forms/flsafety/red-tag-...
http://healthsafety.etsu.edu/docs/fire/Fire_Protec...
Plenty more on line
You might also contact nsfa to see if they have anything
http://www.nfsa.org/
/need and put your name on it????
