How to Tolerance Dimension Having Zero Nominal Value?
Does anyone have any suggestions on how to go about dimensioning and toleranceing in a situation where two surfaces ideally need to be flush but in this case a 1mm overhang and 1.5mm inset is permissable?
I've attached an image showing what I'm trying to do.
I've often been asked to add a limit to two mating parts that have a nominal position equal to zero as in this case.
Thanks!
Ryan
RE: How to Tolerance Dimension Having Zero Nominal Value?
Ryan1220,
Read up on GD&T profile tolerances.
JHG
Thank you!
