flexural torsional buckling stress calculation
Is anybody having how to find flexural torsional buckling stress as per AISC. It is given in compress but does not shows how the formula is derived what the bases is ? please help me.
RE: flexural torsional buckling stress calculation
See http://www.aisc.org/store/p-1578-steel-constructio..., or buy an older used Edition with rules for allowable stress design.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
http://www.aisc.org/content.aspx?id=2884
From the main page (www.aisc.org), go to "ePubs and freePubs" and then click on "Specifications, Codes and Standards" on the left side. The latest version is "2010 Specification for Structural Steel Buildings (ANSI/AISC 360-10), Second Printing". Older versions are also available.
