Regarding Member CS
Regarding Member CS
Dear All,
Let me ask you a question: Is the member forces referred to the local CS o Global CS?.
I did a very simple model, a vertical beam (IPN). One node fixed and the other one with a concentrated force (-1N). Under this assumption, the resulting axial force should be tensile. However this value is negative which I could think as the member is under compression (obviously not)
As far as I know : Tensile: Positive / Compression: Negative
How RISA3D deals with this?.
Thanks in advance for the answers!
RE: Regarding Member CS
