Advanced Simulation - Post View
I'm comparing several versions of a design. Each version is represented in its own Post View in the Post Processing Navigator. I find it very convenient to be able to jump back and forth between the different Post Views, or even to show them side-by-side, in order to compare their deformations etc.
My problem is that it takes quite some effort to create the different Post Views, and that they all dissapear all the time. For instance, all Post Views dissapear if I look at something in the Simulation Navigator. Is there a way to make the Post Views stick? Can they be saved?
/hpon
/hpon
RE: Advanced Simulation - Post View
