Boiler level control
I am doing a project about boiler level control so i don't need a complicated boiler i just need to design the outer body shell. there is no problem in determining the thickness, but what is the appropriate diameter and length for a 30 psi boiler. (after determining the amount of steam required how do i calculate the volume of water in the boiler? )
