Reverse Slug Catcher
Hi I have serched on internet for long time but could not find what exactly I am looking for.
My issue is not liquid slug in the gas line but gas slug in the liquid line. Let me explain the situation little bit.
1) Mainly Liquid line with dissolved and entrained gas - which separates out on high point of the line.
2) Liquid line is 24" dia , 15 km long - residence time in the line is sufficient to separate gas from liquid and accumulate at high point. High point is about 10 kn from the facility.
3) High point is in middle of no where - no utilities available, no flare system etc
4) Separated vent gas could be sent to near by produced gas line. Liquid is not acceptable if selected to send the vent gas to this line
At this stage I would like to know capabilities of various vendorsand would like to know different kind of slug catchers you have designed/supplied.
I can provide more information.
Paresh
Paresh
RE: Reverse Slug Catcher
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
Great work David, as usual indeed!
If you feel like kindly do share with us.Nevertheless you do deserve a pink star!
However just a small query has it something involving very high vents at various points of subject pipeline and gathering these vented materials at a central point for re-use or collection.
Basically the gas being higher in gravity than liquids; please confirm if I am conceptually correct in this connection! Or guide me otherwise.
Best Regards
Qalander(Chem)
David Simpson, PE
Thanks again, it is even better and more refined professional approach worth admiration.
Best Regards
Qalander(Chem)
