Anchored Solider Pile Wall Design
I am designising a 10 meter high solider pile wall for excavation purposes. I am struggling with the anchor spacing. What is the best method to determine the most efficient anchor vertical spacing. Thinking of using 3 rows of anchors. I am using Wallap for my analyses.
Thanks in advanced.
Thanks in advanced.
RE: Anchored Solider Pile Wall Design
I generally try and space my anchors so that the moment in the soldier pile is about the same between anchors and below the bottom anchor. That way you are using the soldier pile effectively. Then you have to look at the anchor loads and make sure that they are reasonable for the soil conditions, bar sizes, etc.
Mike Lambert
www.PeirceEngineering.com
