Basic hydraulic piston/rod seal design
Hi All,
While I've got a bit of experience incorporating standard o-rings and grooves into designs for low-pressure plumbing equipment, I've recently been thrust into a bit of fluid power stuff as well.
I'm struggling to find information about best practices for creating a robust and reliable piston-to-rod seal. It's easy to find gobs of information about gland-to-rod seals, and piston-to-cylinder applications, but not for the piston/rod interface. This is for a very basic hydraulic cylinder, with a target operating range of 2500-3000 psi. Historically, we've used a basic radial o-ring (no backups) to create this seal, but I'm not confidant that will work for the intended pressures. A face sealing o-ring on the top or bottom of the piston can get to a higher pressure capability, but I'm not sure how to approach sizing a face seal gland seeing pressure from both sides. Is there common seals made for these applications? Thanks as always.
RE: Basic hydraulic piston/rod seal design
Ted
Ted
JP.
