valve - what causes a leak
hi
1-corrosion.
2-errosion.
3?
RE: valve - what causes a leak
1- corrosion
2- erosion
3- worn seats
4- seal or packing failure
5- poor casting of body or bonnet (Cast valves)
6- stress crack in body or bonnet (Forged valves)
7- loose packing gland nut
prognosis: Lead or Lag
is greasing affects the leaking?
ALL THIS PLUS HIGH SPEED FLOW MAY ALSO AFFECTED
