Wind load-odd shaped building
Please see the attached sketch. My question is in regards to wind load on this odd/angular shaped building. It would probably be conservative to treat the two portions, A & B, as separate buildings (as shown in the lower sketch) but I am wondering how the code(ASCE 7-05) addressees the issue. Keep in mind that the building is essentially one structure. So would it not make sense to apply the load in two perpendicular directions as shown on the top sketch?
Thanks.
Thanks.
RE: Wind load-odd shaped building
