Concrete column starter bar welding
Hello everyone. I'm new in here and new to structural engineering. I need help on welding 1st floor column rebar to starter bar (300mm) but I'd like to make this question for general rebar welding. If you can please give me answers from Eurocode or BS. ACI will help me to understand the procedure, I believe ;)
1...What is the min welding length
2...What type of welding? Electric or any other type? Fillet or groove?
3...Can you give me website links for note/worked example?
Many thanks in advance :)
RE: Concrete column starter bar welding
Where I live we don't weld them, only tight them (Efficiently) to the new bars.
You should maintain the required anchorage length.
So..any suggestions on welding please??
Regarding the loss of time, it has been already 5 days since you posted the question.
http://www.ancon.co.uk/products/reinforcing-bar-co...
