How do I convert bi-directional rotating energy into a single direction?
I have a rod that fluctuates axially back and forth approximately 30deg. I want to take that input and produce an output that constantly rotates in a single direction.
The only example I've been able to find is the Kobalt Double Drive screwdriver. Seen here: http://www.youtube.com/watch?v=cCbO4No8LiE
I'm certain there is a special name for that type of gear set, but I cannot find out what it is.
Any ideas? Thanks
Any ideas? Thanks
RE: How do I convert bi-directional rotating energy into a single direction?
Can you attach two gear drives, each through a ratchet? Obviously, you will not have constant speed.
JHG
Ted
Walt
