Inconel Tubes to CS Tubes welding
We have to qualify the WPS for welding inconel tubes (SB625) with SA192 tubes.
Please suggest suitable GTAW wire?and any other guidelines?
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
RE: Inconel Tubes to CS Tubes welding
Inco 82 would be my first thought, Check the Special Metals welding guides.
Plymouth Tube
This is an odd combination of dissimilar materials for a butt weld joint. I would agree you should use SFA 5.15 ER-NiCr-3 (Inco 82) filler metal with a standard 37.5 degree, vee-groove weld prep for tube to tube butt welds. I would use the GTAW process. I would perform liquid PT after butt welding.
Do we need back purging with inert gas?
Nasir
Welding Engineer
PAKISTAN
Yes!!
