Hidden lines in AutoCAD
Hi all,
When I convert SW drawing to AutoCAD (Save AS Dwg file) sometimes hidden lines in AutoCAD become visible (full line instead of dotted lines).
Any suggestion.
Any suggestion.
RE: Hidden lines in AutoCAD
I also change the text styles to ROMANS. I have to run this command 2 times as the first time the command changes some SolidWorks text style to a True Type font that is noticeably darker than the other text.
