Aluminum in Concrete
We have an aluminum hatch and frame to be embedded in concrete in a relatively dry environment, but it can be subject to occasional wetting. The high pH of concrete causes corrosion of the aluminum. The frame has come pre-coated to prevent contact and there are some 'scuffed' areas where the coating has been removed. We will endeavour to get info from the supplier about the coating system.
Is there a coating system that can be used to protect aluminum in concrete?
Dik
Dik
RE: Aluminum in Concrete
Dik
