Book recommendations
Hi, currently I am working on a few sensors and parts that I need engineering info on. Can you please provide recommended books on the following parts and categories:
-Tire pressure monitoring systems
-Ignition coils and it's relation to an engine's RPM
-Engine's, and all it's technical info like calculating spark timing, frequency on vibration and such.
-Variable valve timing actuators
-ECU's how they are designed and how they take input data from sensors, calculate the data and give an output.
I appreciate the help,
Thanks!
Thanks!
RE: Book recommendations
In my experience, books can be useful for general background knowledge, but on an ECM by ECM basis, there are always differences in how data is managed.
In general, I'd suggest starting off looking at either an EFI101 type website, or maybe Megasquirt, as a resource for general theory. If you are looking to do things at an OEM level, you need to quickly work beyond what they provide. The last time I looked, they did not really cover EMI/EMC, design for manufacturability, or many other issues OEMs design for.
If you need specific information on particular systems, it would be tough to beat factory documentation on each particular item, especially ECMs/PCMs. For sensors and the like, you should be able to find data sheets relatively easily. If you're trying to reverse engineer factory systems and/or need OEM-level information without OEM-level access, well, all I can say is I feel your pain. I still have a sore spot on my forehead from smashing into that wall.
I am going to check the SAE books also as they have some good selections at times.
crerus75 : Where can I find data sheets on sensors?
The published data always tends to be vague and general.
Often the individual component manufacturers have data they will share only with parties where they see some sales or a mutual interest. They may require confidentiality agreements before disclosure. That gets tricky when they disclose secret info you already had as your secret also.
What is a sharp black line in the minds of the developer, is often a grey smudge in reality. The line between true innovation and the next logical step to someone well versed in the art is the cause of much conjecture.
Anyway back closer to subject, I expect you at the level you seem to be seeking, you will find reluctance due to the information being regarded as proprietary. This might or might not be justified, but it is what it is.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
If you work for Ford's powertrain lab, Bosch will happily discuss fuel injector and ECM characteristics with you. If you are an independent, they won't even take your calls. You definitely won't find a single book that has specific characteristics of the components you listed for various manufacturers simply because such a database is too costly and too valuable to share. An ECM remanufacturer might have info on a lot of different systems, but they sure as hell won't share it with you.
Once again, an idea of what you want to do with this info might help. If you want to test a handful of sensors, repair manuals might be of use. If you want to set up a remanufacturing facility or build your own ECU, you'll probably have to reverse engineer quite a bit of stuff.
