Adhesive compatible with hydrazine
Does anyone know of an adhesive that is compatible with hydrazine?
RE: Adhesive compatible with hydrazine
Well...what temperature, what exposure amount, and duration?
I assume you've looked at Eckhardt Schmidt's book. And here http://www.dtic.mil/cgi-bin/GetTRDoc?AD=AD0632287
Some epoxies may be okay for short term, room temp. or so - usually amine-cured epoxies do better than novolac resins. Short chain polyethylene might work, if you want a hot-melt, also at low temps.
This reference talks about an epoxy sealant modified to improve flexibility but maintain hydrazine resistance: http://namis.alionscience.com/conf/tscc/search/pdf...
