cliff edge blends
cliff edge blends
cliff edge blends
Hi
Is there CLIFF EDGE BLEND option in ugnx7.5. I think this option was there in NX4.
RE: cliff edge blends
you can find it in face blend option group contraining and limiting geometry
- select coincident curve
regards
A tip when moving up from NX4;
If you can't find a command then use the Command Finder
Help -> Command Finder
It is also on your Standard toolbar
Out-of-the-box, the Edge Blend will automatically produce a so-called 'clift-edge' blend. Note that this behavior is controlled by the settings found in the 'Overflow Resolutions' section of the dialog. The pertinent option found there is 'Roll on Edges (Smooth or Sharp)'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
