rfs question
5
rfs question
rfs question
Question in attached is from tec-ease. I'm not able to understand the answer. Can anyone help?
RE: rfs question
They are probably trying to say “modifying tolerance by adding RFS requirement to it”, which is also not very clear because you don’t really “add” RFS requirement; it is assumed by default.
I think some people on this forum actually work for tec-ease; maybe they can clarify.
RE: rfs question
the answer would be, more complicated... (4)
RE: rfs question
This is Don from Tec-Ease, Inc. Questions like this should be sent directly to Tec-Ease rather than to post here. And, yes, the answer is "most complex verification techniques"
To CheckerHater, the question did not say 'add", It said "modifying a tolerance" which we all know is the default. for a Checker Hater you sure know how to pick pepper out of fly p___. :)
RE: rfs question
Don, I get used to visiting this forum so much that whenever there is something unsure I post here. Sorry for that. BTW, there is no easy and quick entrance to raise questions in your website.
RE: rfs question
3
Don,
Could you limit yourself to attacking idea and not the person?
Thank you
RE: rfs question
If something is at RFS and then it's modified, what becomes of it?
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
RE: rfs question
Kenat,
May I have youe opinion as a profesional; isn't it checker's job to pick pepper?
RE: rfs question
It is Peter Piper's job, but only if it's pickled and in quantities of a peck.
Powerhound, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: rfs question
Inspecting a pickled pepper would involve the most complex verification techniques, with all the straightness and circularity error that is likely to be present. Eventually you have to pay the piper.
Is a pickled pepper even a feature of size in the first place? Perhaps we should have specified Surface Profile instead ;^).
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
RE: rfs question
CheckerHater,
Did you not notice the smiley :) at the end of GDTcoach's post?
GDTcoach,
I believe the correct phrase is "Picking the fly s--t out of the pepper".
