Splined Shaft in solidworks
Hi everyone,
I am trying to create a solidworks model of an involute splined shaft, in particular the male externally splined shaft. I was wondering if anyone has any idea how to create an accurate model. I found articles reffering to software called SplineGen but have been unable to find the software online. Does anyone have any ideas as to how to create a spline model to accurate dimenstions in solidworks or know of any software or add-ins that i can use?
RE: Splined Shaft in solidworks
James Spisich
Design Engineer, CSWP
radii that you specify must be producible.
in other words not to large & it cause it run out into the tooth profile .
for ansi splines there is very little clearance between the tif & root on a flat root side fit
it will depend on the spec of the spline you are using.
Mfgenggear
if it can be built it can be calculated.
if it can be calculated it can be built.
