carbon fiber lining
carbon fiber lining
carbon fiber lining
Dear colleagues;
Im trying to simulate a steel tube reinforced with carbon fiber linings but im stuck how can i tie shell with ccontinun elements; or how can u simulate it in the right way!
Pablo
RE: carbon fiber lining
Hi Pablo,
You may want to look into assigning a composite shell section to a skin created on a 3D geometry (property module) to represent the composite lining.
Firehole Composites
www.firehole.com
Thanks for clarify but, can you tell me how can I be able to select a skin, in order to assign composite shell properties, because when I tried, abaqus cant let me do that.
Pablo
When Abaqus prompts you to select a region to assign a section, there is a drop-down menu at the top that is defaulted to Region but you can also select Skin to select the skin(s) you created.
Firehole Composites
www.firehole.com
