Recommendation for pumping wastes at gas conditioning plant
I have a project at a gas conditiong plant in eastern Europe. I am interested in a pump recommendation at a waste facility at a gas condition plant. At the present time, the waste material is being dumped into a sludge pond. We have plans to install alternative treatment facilities to clean up the waste stream and the site. The dissolved solids are so high that the treated liquid will be deep well injected. The flow averages about 8 m3/hr or so and the pump discharge pressure should be about 50 psi. Trucks deliver to the site and off load.
There are issues with equipment sourcing and importation, availablity of pump service, as well as the site being remote. The waste parameters are listed below for the worst case.
40000 mg/l suspended solids
4000 mg/l hardness
11000 mg/l oil
7 to 10 pH
20000 Suspended ash (50% FE, 20% Hardness, 45% Other/Grit)
7500 FE
400000 mg/l COD
The waste consistency can vary from truckload to truckload with the heaviest solids being generated from tank bottoms during the periodic annual shut downs. In short the consistency varies from an oily liquid to tank bottoms.
Is there any pump on the market that can meet these requirements? Does anyone have any experience with the wastes that have been described.
4000 mg/l hardness
11000 mg/l oil
7 to 10 pH
7500 FE
400000 mg/l COD
RE: Recommendation for pumping wastes at gas conditioning plant
