DOF Springs???
DOF Springs???
DOF Springs???
Hello Forum,
I've been reading about modeling fasteners on the web and all sources suggest to use "spring/damper" elements (CBUSH) in lieu of DOF Springs.
My question to you is:
What are "DOF springs" used for???
Thank you,
Whyowhyowhy
RE: DOF Springs???
providing a elastic connection between pieces, like rivets.
RE: DOF Springs???
@rb1957
Aren't "Spring/Damper" elements (CBUSH) preferred for any type of fasteners (including rivets)?
RE: DOF Springs???
CBUSH = dof spring ... CBUSH is the NASTRAN element (used to be CELAS), "dof spring" is FeMap modelling
RE: DOF Springs???
I'm working with FEMAP Version 10.2.1A (preprocessor) and NX Nastran (solver) and it's telling me that my "DOF Springs" are CELAS, not CBUSH.
RE: DOF Springs???
does it matter ? if the data input for your dof spring is a single stiffness in a specific direction, then it's a CELAS. if the input is more generalised (mulitple stiffnesses, rotational stiffness, damping, ...) then that sounds like a CBUSH. looking at the f06 or your user manual should tell you the specific element used in analysis.
looking at the data entry i have (FeMap 10.3), "dof spring" has a single stiffness (= CELAS) and "spring/damper" multiple (= CBUSH).
look at the f06 to be sure.
RE: DOF Springs???
I've noticed a difference in results obtained when using a CBUSH element vs using multiple CELAS elements to simulate a fastener with tension/shear capabilities.
Why and how is this different?
Thank you,
Whyowhy
