Modelling composite reinforced concrete and steel
Hello
I have modeled a building structure using beam and shell elements. How can I create a define steel reinforcement within a shell element?
John
RE: Modelling composite reinforced concrete and steel
I should have specified that I am using ANSYS Workbench.
John
You can try and overlay the shell with beam elements, this would give you a first approximation of reinforcement.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Hi and thanks for the tip.
I have added the beam elements to existing surfaces using the 'split edge' command in design modeler and then adding a beam. Now when I do the analysis it seems that the shells are not 'interacting' with the bean elements. I have used 'form new part' but how do i make sure that the shell is in fact acting in conjunction with the beam elements that I have bisected the existing surface with?
thanks
John
