Pad Print Protection
I am having some artwork pad printed on a part, but am concerned with the durability of the pad print over time. The part is a component of a consumer product, and will go in pockets, briefcases, etc. I fear that it will noticeably wear over time due to these types of environments. Although the loads are low, the number of cycles is high.
The pad printing operation is being performed on a mirrored surface. I am looking for some kind of secondary op I can perform to further protect the pad printed art work. I am thinking some kind of protective coating/sacrificial layer, but am open to any ideas!
Please let me know if you would like any further clarification. Any guidance is greatly appreciated.
RE: Pad Print Protection
Mfgenggear
if it can be built it can be calculated.
if it can be calculated it can be built.
also laser marking is an other option over metal.
Mfgenggear
