Differents products assembly with same parts
I would like to be able to have different configurations of the same parts to be able to compare weight distribution and center of gravity.
The problem is, If I put all my parts in a product and then save it as a different product, the links are all still there so when I move parts in the new product, they move in the first one also.
I tried to do different scenes in a products so once I would have place my parts correctly, I would apply the scene to the assembly and then calculate the center of gravity. BUT working whithout constraints is a real mess.
Thank you for your answers
RE: Differents products assembly with same parts
You answered your own question. You should work with part constraints within the product. Publish constraint geometry then build it this way.
Product A
Product B
Part A
Part B
Part C
Constrain the items.
Copy/Paste Special --> Break link Product B
This will result in Product C
Part A
Part B
Part C
modify constraints or change parts, add parts,...
Instance copies will be your friend.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
This can be done in different ways, Derek suggestions is good.
Another way is to use New From option. Take a look here , probably you will understand more. When you are using New From , I believe you can rename also everything.
Then just load your main products versions in a single one to compare them.
Fernando
https://picasaweb.google.com/102257836106335725208
Thank you, this was very usefull.
