Scrub radius and wheel width
2 questions.
1. If a wider tyre is placed on the standard factory rim does it effect the scrub radius assuming the diameter is the same?
2. If a factory wheel is say 8 inches wide and has a offset of +50mm and it is replaced with a new wheel 9.5 inches wide with an offest of +50 and a wider tyre is the scrub radius changed (assumming the diameter is unchanged)?
RE: Scrub radius and wheel width
If you have some air bearings or grease plates, you can sometimes measure a scrub radius CHANGE under lab, non-rolling conditions, especially if its pretty large (25+ mm) already. You need to determine the arc center of the plate movment and compare it to the center of the tire position. In reality, the center of the tire is NOT the centroid of all the forces and moments, but you can get the hang of it. Since the wheel is wider, the tire spring rate is usually different, so you may have lost the 'same diameter' constraint.
You probably won't read any of this in a book. Get someone to invite you into a laboratory tire test session and have them crank it to the load (Fz), slip and camber angles that your car runs and observe the Mx/Fz math channel.
I can probably come up with some sample results to post if I can figure out how to show pictures/graphs AND after I get my barn's burst water line fixed. Stay tuned...
