Doubts in SKM Power Tools..
Hi frnds!!!
I am new user to SKM Power Tools. Could you clarify my doubt???
Here it is..
I have modeled power system contain 10 diesel generator sets(6600V ph -ph, 1500kva) connected to a bus(MV distribution Panel. which will feed various LV distribution Panels through RMU networks and MV transformers. My problem is, When i run a Balanced system Studies. It shows error msg like... "Gen 8 to Gen 10", "Redundant Swing Bus defined"
Can you give a solutions to rectify this one???
Thanks In advance.
Vinoth
Here it is..
Thanks In advance.
Vinoth
RE: Doubts in SKM Power Tools..
What is your doubt about, the tool or yourself?
If you are doubting the tool, and as long as it is the full paid for version, I wouldn't have much doubt over SKM PT.
Running the balanced system check before your system layout is complete will always produce advisory comments (I'm not sure I'd call them 'errors')to ensure you have everything in place.
The terminology SKM use for a 'bus' may be different to your terminology of a bus. Worth double checking.
SKM's FAQs are pretty good, check them out. E.g : http://www.skm.com/faq_loadFlow5.html
