Pressure Vessel Manufacturer?
We have a 3000 psi air pressure vessel on an offshore rig. The data plate on the vessel has all the usual working and test pressure information, date of manufacture on it. However, it also has the following C.A.M. on it which I assume to be the manufacturer.
Can anyone advise me on C.A.M. - what is the company/organisation and where are they located.
RE: Pressure Vessel Manufacturer?
www.c-a-m.com
See data plate photo
you should have a U-1A form available to see which plant manufactured the vessel.
http://www.campisrl.it/en/campi-quality-department...
Plymouth Tube
