Boiler Rm Heat Control
Looking for options for providing heat control in a boiler room.
It has steam boilers and domestic water heaters.
It does not have high-low air inlets. This is the first option but it may not be enough. The room is underground so it will be hard to install (will probably do it anyway). It Currently has a couple high louvers (probably under sized).
Some of the piping and breeching is not insulated. (second thing that needs to be done)
Don't want to install an exhaust fan due to the boiler venting.
Just looking for other things to consider.
RE: Boiler Rm Heat Control
I can't imagine any situation where I would use mechanical cooling.
I was thinking more of fans with variable speed control so a nuetral pressure can be maintained with variable firing of the boilers and heaters.
I was think of an exhaust fan to control temperature and a supply fan to control pressure.
