Uniting All Objects on a Layer
Is there a function that can be used in a journal to unite all bodies on a given layer? We often have scenarios where we copy all bodies in view to a single layer and then unite all and I am looking to automate this process. I already know how to automate the copying portion, and am hoping that the uniting is similarly simple.
We run NX8. Thanks in advance for any help.
RE: Uniting All Objects on a Layer
Do you care which solid is the "target"?
www.nxjournaling.com
No, it makes no difference as long as all the bodies are united in the end.
Do all the bodies always properly intersect the "target"? There might not be a logical way to do all the unites in a single operation.
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
Here's a quick journal. It doesn't do any error checking, we'll have to add code to fix problems as you find them. If one of the solids doesn't intersect the others (and it is not designated as the target), it will disappear and there will be a warning message on the unite feature. This behavior is no different than interactive NX and you can roll back and edit the unite to fix it, so I didn't add any checks/fixes for this. Currently, it unites all the solids on layer 1. Change the value of the myLayer variable to change this.
CODE
'Unite all the solid bodies on a given layer
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim myLayer As Integer = 1
        Dim bodiesOnLayer As New List(Of Body)
 'get list of solid bodies on given layer
        For Each temp As Body In workPart.Bodies
            If temp.IsSolidBody And temp.Layer = myLayer Then
                bodiesOnLayer.Add(temp)
            End If
        Next
 'MsgBox("there are " & bodiesOnLayer.Count & " solid bodies on layer " & myLayer.ToString)
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Unite solids on layer " & myLayer.ToString)
        Dim nullFeatures_BooleanFeature As Features.BooleanFeature = Nothing
        Dim booleanBuilder1 As Features.BooleanBuilder
        booleanBuilder1 = workPart.Features.CreateBooleanBuilderUsingCollector(nullFeatures_BooleanFeature)
        Dim scCollector1 As ScCollector
        scCollector1 = booleanBuilder1.ToolBodyCollector
        booleanBuilder1.Tolerance = 0.001
        booleanBuilder1.Operation = Features.Feature.BooleanType.Unite
        Dim added1 As Boolean
        added1 = booleanBuilder1.Targets.Add(bodiesOnLayer.Item(0))
bodiesOnLayer.  Remove(bodiesOnLayer.Item(0))
        Dim scCollector2 As ScCollector
        scCollector2 = workPart.ScCollectors.CreateCollector()
        Dim bodies1() As Body = bodiesOnLayer.ToArray
        Dim bodyDumbRule1 As BodyDumbRule
        bodyDumbRule1 = workPart.ScRuleFactory.CreateRuleBodyDumb(bodies1)
        Dim rules1(0) As SelectionIntentRule
        rules1(0) = bodyDumbRule1
        scCollector2.ReplaceRules(rules1, False)
        booleanBuilder1.ToolBodyCollector = scCollector2
        Dim nXObject1 As NXObject
        nXObject1 = booleanBuilder1.Commit()
        booleanBuilder1.Destroy()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
 'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
Cowski that is really excellent. Thank you very much.
All the bodies should be intersecting any time we perform this function, so it should be fine. As you say, the unite function is always something we can edit.
As this worked so well, would it then be possible to subtract all the bodies from another layer from the bodies on the layer that just got united. So, let's say we used what you have already written to unite everything on layer 200. I would want to then subtract some bodies on layer 205 from the united bodies on layer 200. It would be preferable if the bodies used for the subtraction on layer 205 could be kept (like choosing the 'Keep Tool' box in the 'Subtract' interface). Would this work?
Change the layerUnite and layerSubtract variables as needed.
This is a lot of cut & paste from the journal recorder, so it could probably stand a little more cleanup but seems to do the job.
CODE
' then subtract all the solid bodies on a given layer from the resulting solid
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim layerUnite As Integer = 1
        Dim layerSubtract As Integer = 2
        Dim bodiesOnUniteLayer As New List(Of Body)
        Dim bodiesOnSubtractLayer As New List(Of Body)
            If temp.IsSolidBody Then
                If temp.Layer = layerUnite Then
                    bodiesOnUniteLayer.Add(temp)
                ElseIf temp.Layer = layerSubtract Then
                    bodiesOnSubtractLayer.Add(temp)
                End If
            End If
        Next
 'Unite solids on specified layer
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Unite solids on layer " & layerUnite.ToString)
        added1 = booleanBuilder1.Targets.Add(bodiesOnUniteLayer.Item(0))
bodiesOnUniteLayer.  Remove(bodiesOnUniteLayer.Item(0))
        scCollector1 = workPart.ScCollectors.CreateCollector()
        Dim bodies1() As Body = bodiesOnUniteLayer.ToArray
        scCollector1.ReplaceRules(rules1, False)
        booleanBuilder1.ToolBodyCollector = scCollector1
        Dim uniteFeature As Features.BooleanFeature
        uniteFeature = booleanBuilder1.Commit()
        MsgBox("united bodies: " & uniteFeature.GetBodies.Length.ToString)
        Dim unitedBody As Body = uniteFeature.GetBodies(0)
 'subtract solids from specified layer
        Dim markId2 As Session.UndoMarkId
        markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Subtract solids on layer " & layerSubtract.ToString)
        Dim booleanBuilder2 As Features.BooleanBuilder
        booleanBuilder2 = workPart.Features.CreateBooleanBuilderUsingCollector(nullFeatures_BooleanFeature)
        booleanBuilder2.Tolerance = 0.001
        booleanBuilder2.Operation = Features.Feature.BooleanType.Subtract
        booleanBuilder2.CopyTools = True
        Dim added2 As Boolean
        added2 = booleanBuilder2.Targets.Add(unitedBody)
        Dim bodies2() As Body = bodiesOnSubtractLayer.ToArray
        Dim bodyDumbRule2 As BodyDumbRule
        bodyDumbRule2 = workPart.ScRuleFactory.CreateRuleBodyDumb(bodies2)
        Dim rules2(0) As SelectionIntentRule
        rules2(0) = bodyDumbRule2
        scCollector2.ReplaceRules(rules2, False)
        booleanBuilder2.ToolBodyCollector = scCollector2
        nXObject1 = booleanBuilder2.Commit()
        booleanBuilder2.Destroy()
    End Sub
    End Function
End Module
Thanks again cowski. I probably won't have too much time to mess around with this today, but I wanted to thank you while the thread was still on the front page.
