New problem, Mazak SG MKII 510. Angle A,B and L1,L2 calibration
After cutting some beveled ring parts we noticed a .75mm difference from one side to the other. After checking plate flatness(which was only out by 2mm over a 8 foot span) and running the calibration procedure it appears that the angle B calibration is not holding for some reason. I can dial it it to .01mm difference and then just run the cut again and get up to a .2mm difference. .08mm is the acceptable. error. Has any one else run into this problem or have any insight to what mat be causing it?
RE: New problem, Mazak SG MKII 510. Angle A,B and L1,L2 calibration
Thanks for the help
