Application of flash specification
Hi guys, hope this is the right area to be asking this question...
I'm seeking guidance on the application of specifications for defects such as flash. I will use an example to explain this.
If you are measuring the overall length of a component/feature and there is flash on one end of the feature some of our quality folk seem to think the flash needs to be within the tolerance for that feature. As far as i am concerned there is a specific tolerance for that feature which always applies and there is (or should be) a separate tolerance for flash i.e. you measure the feature length excluding the flash then apply the flash spec to the flash itself.
My problem is convincing Quality I am right. Do you know if there is any official referece or standard which provides guidance on such matters?
Any & all help appreciated!
RE: Application of flash specification
"The limits of permissible flash extension shall be specified on the drawing. Flash extension may exceed perfect form boundary at MMC unless otherwise specified."
In my opinion this proves you are right and not the quality guy.
I presume "Flash extension may exceed perfect form boundary at MMC..." means that the feature length in my example can be at the upper tolerance limit and flash can still exceed this.
This is very helpful, thanks!
Do ou have specifications for the limit of permissible flash extension on your drawings?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
dgallup - that sounds like a good approach to me!
KENAT - i'm in Europe but many of our customers are US based and would use ASME standards. I must get my hands on Y14.8.
We generally have (or will ask for) a spec for flash on the drawings, even so this argument comes up with Quality :)
