Mouse Operation
Mouse Operation
Hi there everybody!
I'm operating ACAD 2000 on an Win XP operating system and I am having problems setting up my mouse properly. I have a Logitech wireless scroll wheel mouse and I cannot set the scroll wheel to operate as zoom in/out. Right now it will scroll up/down. Can someone tell what to do to fix this?
Rusk
Rusk
RE: Mouse Operation
RE: Mouse Operation
RE: Mouse Operation
This is for Windows 2000
If you go to the desk top and double click on the MY COMPUTOR, then CONTROL PANEL, then MOUSE, then choose the WHEEL tab. It has a troubleshooter section.
You will need to go through this process when you have trouble with your AutoCAD drawing. It will ask you to choose the drawing that you are having trouble with.Hope this helps.
RE: Mouse Operation
Set your scroll button to AutoScroll using the Logitech driver Setup Buttons tab. It had defaulted to Universal Scroll which evidently does not work with mbuttonpan. Change the setting to AutoScroll.
Select USE MSOFFICE compatible scroll only. (Not entirely sure this setting is required.)
This way I was able to use the Logitech driver and all the features of my 5 button MX310 mouse.
I'm using Mouseware 9.78.
Good luck.
RE: Mouse Operation
RE: Mouse Operation
Does your mouse have the 4th "thumb" button on the side? If so, after you uninstalled the logitech software does this button still work?
RE: Mouse Operation
RE: Mouse Operation
