Negative Jacobian error message on Modal Analysis
Every time I attempt to run a modal analysis on my model I get the error message:
* * * E R R O R * * * (WHILE RUNNING ANALYSIS)
NEGATIVE JACOBIAN ENCOUNTERED,
CHECK ELEMENT CONNECTIVITY AND JOINT COORDINATES FOR ELEMENT 1147
Now, I have two questions. How could I find an element in etabs and someone knows why did it happened this error.
RE: Negative Jacobian error message on Modal Analysis
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
