Switching Gears - Buildings to Industrial
Just took a job with a big industrial firm in the structures department. My experience has mainly been with building design. I was told that there is very little involvement with architects, and that most of the work is platforms, racks, pipe and equipment supports and such. Also, that alot of the clients don't required S&S drawings.
Is there a big leap from going to industrial structural engineering from building structural engineering? Am I going to be completely out of my element? I figured steel is steel and concrete is concrete, but I wanted to get the opinions of engineers that have gone from one side to the other.
RE: Switching Gears - Buildings to Industrial
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Another nice aspect is being part of a company's overhead, not a unit of production. The industrial money comes in by selling as many products as possible, not by whipping the professionals into working as many billable hours as possible.
I know an architect that you can call every now and then if you get to having withdrawals from daily irrational thinking, impossible demands, and unspeakable deadlines. If you'd like, he would be happy to relieve you of half your pay for "coordination." He could even give you a 6" square chase to run three 4" pipes through, or a 9" high ceiling plenum through which you have to air condition 25,000 square feet of building. Fond memories.
Just let me know. I'm sure he would welcome the opportunity.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
You are starting to get me all teary eyed about what I am leaving behind.
I left industrial to go to buildings. I miss some of the projects from industrial. It's just different...instead of working on one building which is the entire project, now you might have 5-10 different structures which must be coordinated all within one project. Just a different set of skills.
It's all still structural.....shear, moments, and deflections control everything no matter whether they are caused by pipe thrust, temperature, or occupancy loads!
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
