material selection for pressure vessel
I'm working on making a pressure vessel that will be exposed to Argon, CO2, air, Helium, and nitrogen. I was wondering if anyone could point me in the right direction for references or standards regarding the material selection of such a system.
RE: material selection for pressure vessel
We are in the design process right now so the instrumentation and sample size (samples we will put in the chamber to test) will determine the size of the vessel. I hope the range I gave will be helpful enough.
Mike
I'm not sure if you were trying to make me laugh but that was hilarious! Obviously it is going to be metal.. It's under 1500 psi. I need help getting references to different steals regarding material selection. What can and can't be used under 1500 psi in an Argon/Heleium/CO2/Nitrogen/Air environment.
